Help wifi is acting up !
Solved by Muffinmaddness,
http://downloads.dell.com/FOLDER02953394M/1/Network_Driver_YN67N_WN32_17.16.0_A04.EXE
ok, download and install this see if it helps with the ethernet, we'll start from there and then sort out your wifi =)
site is the official dell site for your laptop. drivers are for ethernet adapter if those dont work try these
http://downloads.dell.com/FOLDER01975747M/1/Network_Driver_NTPXD_WN_8.20.815.2013_A00.EXE
download the first link install try connecting through ethernet, if that doesnt work try the second one,
if you have access to another computer then download them from there copy them to your phone and copy over to the laptop, or use a flash drive, which ever you have
also can you quote so i know you have replied, thanks dude
