it's probably a dry bearing - are they unstable or just noisy?
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6099993
I'm pretty sure they are unstable as at higher speeds the rattling is non existent.
I mean set the speed to when it rattles and look at it - if it behaves weirdly and if it's unstable - as in wombling around - then it needs replacing. if it's stable then it needs WD40
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100010
If they are just noisy and don't wobble, you could try taking the card out. turning it up-side down and putting a drop of 3-in-1 oil into where the fan splits.
I'll probably get shot down for that but it has worked in the past, as long as you don't soak the thing in it. '
But if your fan wobbles horribly don't bother your fan is shot.
Thanks!
Chris R.
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100015
*shotgun loading sounds*
Don't mind me, I'm just watching :)
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100026
Hah - I know the feeling :/
It's definitely stable.
WD40 is your friend, car oil is your nightmare :P
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100050
Edit: I just noticed something, my 270x's fan in question stops rattling if I put a little pressure on the card itself. What does this mean?
Pressure? As in?
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100061
If I lift up or touch my 270x the rattling goes away.
Hmmm - could be a broken bearing but that's more unlikely. can you make a video of it?
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100112
sounds as if your fans off kilter, push the fan in quite hard pressing the centre of it ( while its off)  then slightly tilt it with your thumb doing a circular motion ONLY SLIGHTLY) then pop the card back in and it should have sorted it. unconventional, but it does work =)
Specs
CPU-Intel I7 4790K- @ 4.5Ghz / Mobo - Asus Maximus Hero VII / GPU - GTX 980 @ 1592MHz / RAM - 16Gb Corsair Vengeance Pro @ 2400Mhz / Cooler - Corsair H105 / SSD - Samsung 250gb 840 EVO / HDD - 2x 2tb Seagate/3x 3tb Seagate / PSU - Corsair RM1000 / Keyboard - Corsair K70 / Mouse - Corsair M65 / Case - Custom Glass panel Corsair Obsidian 750D -  Still saving for upgrades =)
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100142
Funny I actual have the same problem with one of my cards. when I ramp it up to exactly 55% on speed fan it 'rattles' but if mine dies I can finally ditch these 260x's for a 960 :D
960? HERESY! BLASPHEMY! SACRILEGE!
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100154
Lets say I try everything and the problem persists, if I set my fans to a speed where they don't rattle, will my fans by ok?
yeah but eventually they will break, they are just plastic, and my have a negative effect on cooling, just monitor the sound and temps, and you'll be fine
Specs
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6100164
Ok, I think lubing it will fix it BUT, doing what muffin said made it so that it rattles soo slightly that it's not there anymore Thanks guys! But I have one concern, I realize that my card is sagging abit, like 1.5 cm.
if it still rattles do what i said a little harder.. but not to much!, dont hulk smash it or anything ;) ,can you post a side pic so we can see the card sag, will help us determine if its to much or something not to worry about =)
Specs
https://linustechtips.com/topic/454676-gpu-fan-rattling-help/#findComment-6101086
