My Budget is around 1500 USD, I live in Norway so prices are a bit different so around 16000nok, I have all ready a screen an DELL U2711B, and keyboard and mouse, so should I go for this SLI setup
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Storage: Kingston HyperX Fury 240GB 2.5" Solid State Drive  ($92.00 @ Adorama)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card (2-Way SLI)  ($319.99 @ Amazon)
Total: $1560.14
Generated by PCPartPicker 2015-09-21 11:34 EDT-0400
Or should I go for this setup?
Video Card: Zotac GeForce GTX 980 4GB AMP! Edition Video Card  ($489.99 @ Amazon)
Total: $1410.15
Generated by PCPartPicker 2015-09-21 12:39 EDT-0400
Feel free to post inquries, sorry again if my english is kind of bad in anyway
https://linustechtips.com/topic/453871-good-first-build/
Total Budget? Also are you in the US?
Corsair fans are really poor just fyi and you don't have any reason to use them anyways.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/453871-good-first-build/#findComment-6088045
go with a 980 ti if you can, best performance you can get in a single card thats worth buying
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/453871-good-first-build/#findComment-6088070
Go for a 6600k with the apropriate motherboard, along with 16gb of DDR4 ram ( it's only like $90 usd)  and you're good, everything else is fine ( the 970 build ) unless you want to get a 980ti instead of a 970 and eventually upgrade to a second 980ti. ( You'd have to get an SLI motherboard for the 6600k too)
Diamond 5 in League :)
https://linustechtips.com/topic/453871-good-first-build/#findComment-6088099
This is an optimization of the first build. The define S comes with 2 fans, so you need a max of two more to fill out the 4 slots available if top mounted.
CPU Cooler: LEPA AquaChanger 240 103.6 CFM Liquid CPU Cooler  ($79.99 @ SuperBiiz)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($83.99 @ SuperBiiz)
Case Fan: Fractal Design GP14-BK 68.4 CFM 140mm  Fan  ($14.99 @ Newegg)
Total: $1496.35
Generated by PCPartPicker 2015-09-21 12:45 EDT-0400
The fans I choose are quieter yet move more air. The HF-14 venturi fans would be best but they are a bit expensive.
I would however suggest considering a 980ti instead of sli 970 as its about the same price with about the same performance but without the headaches of SLI.
Like so:
Video Card: EVGA GeForce GTX 980 Ti 6GB ACX 2.0+ Video Card  ($649.99 @ Amazon)
Total: $1506.36
Generated by PCPartPicker 2015-09-21 12:48 EDT-0400
Otherwise if doing 1080p gaming instead you could opt for a 980 or a 390 (970 doesn't beat 390 basically ever, but sli 970 uses just over half the power of CF 390 so it's imho a better idea for cooling purposes).
https://linustechtips.com/topic/453871-good-first-build/#findComment-6088105
