This is my first post so if I've done something wrong, please be nice :)
I've recently finished my first PC build and it's running great, the best PC I've ever owned honestly, and as the topic name suggests I need some advice on what to upgrade first as I did build on a budget.
My parts are :
               CPU - Intel Pentium G3258
Motherboard - MSI H81M-P33 LGA1150 M-ATX
              RAM - Crucial Ballistix 240 Pin DDR3 8GB ( 4gbx2)
              GPU - Asus Nvida GeForce GT740
        Storage - Seagate Barracuda 3.5inch 2TB x1
              PSU - EVGA Supernova 650W G1 Gold Modular Power Supply
        Cooling - Stock Intel Fan
Not the best build around, but for my first build/budget I don't think it's so bad.
I should say this, I will be getting more storage as well as an SSD once I have a bigger case, A better GPU isn't a necessity as this PC is mainly for recording not gaming, though I wont turn down any recommendations for one! I think mainly just a CPU upgrade is what I'm after, but why limit myself right? :P
Any and all help will be greatly appreciated, thank you in advance! <3 :D
https://linustechtips.com/topic/453810-need-advicehelp-upgrading-my-current-build/
uhm cpu upgrade that, god that bottleneck.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
When you say Asus Nvidia GeForce GT780, did you mean the GTX 780, or the 7800GT? Didn't know there was a GT780, and Google didn't help me in finding one..
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
Wait until next years CPU/GPU offerings arrive, before making decisions on a purchase
CPU: Xeon X5650 6C/12T @4.87Ghz GPU: R9 390 Strix RAM: 16Gb Kingston Fury 1866Mhz Mobo: Gigabyte EX58-UD3R Storage: Kingmax 240Gb SSD 3x 1TB's Case: Fractal Design Define XL with 480mm Radiators + 360mm Radiator PSU: Enermax Revo95+ 920W Speakers: Logitech Z-5500D THX Surround Sound System Headset: Audio-Technica ATH700X Audio: Creative SB ZxR Moniter: BenQ 27Inch 1920x1080 Keyboard: Microsoft Sidewinder X6 Mouse: Logitech G9x/Microsoft Basic Optical OS: Windows 10 Pro Insider
It's GT740! I type it wrong my bad!
Ahhhh, makes more sense ;P The, contrary to what @Mohenjo said, you aren't bottlenecking with the G3258. I would, however, look into an i5 with a beefier GPU to pair if you plan on doing any sort of gaming, as recording and gaming on the same machine can be taxing on both the CPU and GPU. I don't know which i5s are good, been an AMD fan until I learned that the IPC and architecture of AMD is several years old now, so I would look to someone else to give a better recommendation there. Same goes for the GPU. Though, I think an R9 380 or R9 280x would be a safe bet.
Sadly, due to the nature of your lower-ended specs for a gaming build, it will cost more to get some better performance.
My parts are :
You could probably do with a cheaper powersuppply.
Like a cooler master v550s
I do have an i5 processor in mind to upgrade, I'm honestly not too worried when it comes to gaming with this current build, I'm one of those console gamers you see :P
Thanks for the suggestions though I will definitely look into those GPUs you mentioned :)
Is there any reason in particular to get that power supply over my current one? Sorry if this is an obvious point I really am still slightly clueless when it comes to PC parts
i commented when it said 780 :P
I know :P Just tagging so you know! :D
"next year" what next year? all the gpus that will be out for 3 or 4 more years have all been released... unless you want him to get a 910 or 940 or something....
Well, you dont need more than 500w...that its.
Dont need it? Dont buy it.
And if im not mistaken the Cooler Master V series is higher quality than the EVGA G1 series.
I did not know that, I just assumed I'd need as much power as I could put money into..
I will definitely keep in mind what you've said when I go to upgrade or even make a second PC, Thanks! :)
??? there are new generations every year, you blind? Pascal/Arctic Islands @ 16nm next year
