NEED HELP PICKING RIGHT PCU!
Go to solution Solved by Guest,
I didn't know it was good lol just picked the first recommended one
So I guess I will get the Cooler Master VSM 750W 80+ Gold Certified Semi-Modular ATX Power Supply??
https://au.pcpartpicker.com/part/cooler-master-power-supply-rs750amaag1
I agree with you actually for the price wow best psu reviewer gave it this score:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=383
Seems like the right one I guess.
Thanks, closing thread! +1 and here is your owl meme!
For the same price as the CM VSM the EVGA G2 is a better unit.
Hellooooooo once again like 5th topic in 1 day wtf?
So this time I need a PSU for my ever evolving Gaming Computer (Glad0s 2.0)
I have like EVERYTHING except the damn psu and I want a rlly good one to last me quite a few years :)))
Here is my current build:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($523.00 @ CPL Online)
Motherboard: Asus Z170-AR ATX LGA1151 Motherboard  ($245.00 @ Centre Com)
Video Card: Gigabyte Radeon R9 390X 8GB SOC Video Card  ($599.00 @ PCCaseGear)
Case: NZXT Phantom 530 (White) ATX Full Tower Case  ($189.00 @ CPL Online)
Total: $2110.00
Generated by PCPartPicker 2015-09-21 22:12 AEST+1000
YES YES I know I dont need a 750 watt but idc just make it above 650 because I might get sli/crossfire sometime in the future!!!
So what do you think I should do? I have heard RM series by corsair is good and so is EVGA but idk which one lol? oh yea the evga g2 750 seems pretty sik 2
All help would be massively appreciated and anyone who helps me out will get +1 owl points and a funny owl meme :)
CPU: i7-6700K 4.7GHz GPU: GTX 980 STRIX 1337MHz CPU Cooler: H110i GTX AIO |
 Motherboard: Asus Z170-AR | Case: NZXT H440 White PSU: CS750W |
 PCPartPicker Link: http://au.pcpartpicker.com/p/43BkVn
https://linustechtips.com/topic/453761-need-help-picking-right-pcu/
RM is overpriced, EVGA is good. Get a 650 now, if you're 100% sure about another GPU get a 750 now.
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
I own an RM650i, and the corsair link tool is invaluable. It runs nicely and shows me that I have enough room for potential SLI. If you can afford it, the 7 year complete warranty and great corsair support is worth the extra $.
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
the VSM you currently have is better than the RM, by quite a bit
Do you think you could maybe directly send me a link to something you think would suit my needs? would this be ok?
The thing is I don't really know if I am going to upgrade to crossfire or sli, I am not sure I might and might not depending on life basically so do you think it would be safe going for a 750 watt since the pricing is literally pretty much the same?
650 watt
https://au.pcpartpicker.com/part/evga-power-supply-220gs0650v1
750 watt
http://www.pccasegear.com/index.php?main_page=product_info&products_id=27992&cPath=535&utm_source=googlebase&utm_medium=cse&utm_campaign=export_feed&gclid=CjwKEAjw1f6vBRC7tLqO_aih5WISJAAE0CYwALcYkuBnjSew3xNKKe-jeKPdhBfVCylidUUgAC7mIxoCSD3w_wcB#googlebase
For the same price he can get a SeaSonic X-series which is a much better platform
650 watt
750 watt
The CM VSM is already a fantastic unit - why do you want a different one?
Hate to be "that guy" but its PSU :P (Power Supply Unit)
Hah yea i noticed xD
It's a great PSU by Enhance Electronics - all around solid unit with good build quality, If you want something cheaper then look at EVGA G2/GS, XFX PSUs (SeaSonic Rebrainds) or Antech HCG line.
G2 is Super Flower, VSM is Enhance - both are solid :)
For the same price why would you get the inferior VSM unit ? It is a good psu, but the G2 is better.
Both are solid - whatever he wants, it's his call.
For some reason it does not show up in my compatibility list in pcpartpicker D:
Yea I don't really care about a 2% difference just want it to work fairly efficiently :)
If it's cheaper I guess I will bounce around with either the one I have right now or this one?
EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply
https://ca.pcpartpicker.com/part/evga-power-supply-220g20750xr
yea same exact prices I will go with the evga since I have seen like 0.4 difference in ratings so you know thanks I am done with this thread :D
The EVGA G2 is one of the best for it's price/performance. If it was more expensive then it would be harder to recommend, but at the same price it is a no brainer.
Review - http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=380
G2 is very solid - based on the Leadex platform by Super Flower. Can't go wrong with either really.
