Help with Pump choice
Solved by W-L,
-SNIP-
The D5 pump would be a great option, the PWM or Vario version is mainly a matter of choice if you want software controllable pump speed but I find for the vario just leaving it on the lowest speed works great and you can ramp it up during initial fill/bleeding with the little dial.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory7 -
derekchan ·
Posted in New Builds and Planning6 -
5
4
6
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
