PBworks help!-SOLVED
Go to solution Solved by HumbleMobo,
Nevermind, I solved the problem.  My professional headshot is 5 kilo bytes OVER the max file size which is 200 kilo bytes, fuck the world!  Well I'll crop it and shave off those extra KB's if that will work
Ok, so I'm the president of my club so I figured, I should put a headshot of myself up on my profile.  EVERY, DAMN, FRIGGIN TIME, I select, add my own photo I put in my headshot, and it won't allow it!  I press "Save" and then it deletes my changes!  Help??
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/452334-pbworks-help-solved/
https://linustechtips.com/topic/452334-pbworks-help-solved/#findComment-6065774
