Case Fan doesn't always start up
Go to solution Solved by Naeaes,
It's not uncommon for PWM fans to act up when they're undervolted without PWM...
Hi There;
I have a new case fan installed its a "Raijintek Aeolus B Slim Fan"; The manufacturer states that it has a startup voltage of 7V; I have the fan running at 8.7V.
My issue is that the fan doesn't always start up; sometimes I need to bump the side panel to get the fan to start up.
Anyone have any ideas? Defective Fan? Run Fan at 12V and use a Resistor Instead?
Thanks;
Deven
https://linustechtips.com/topic/451939-case-fan-doesnt-always-start-up/
bump the sidepanel?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Case fan controller or motherboard or direct into the powers?
It is connected directly to the psu, undervolted to 8.7 (12v Positive, 3.3v Negative)
bump the sidepanel?
Fan is installed on the acrylic side window, if I bump it, it gets the fan to spin and start.
Why not get a cheap PWM controller instead? You can get "Buck converters" for as low as $1.00 from eBay. With this you can regulate the 12V supply to output any voltage you want. Heck, get the one with display for $2.50!
http://www.ebay.com/sch/i.html?_sop=15&_nkw=buck+converter&rt=nc&LH_BIN=1
CPU: Intel i5-8600K 6C 3.6 GHz | MOBO: ASUS Prime Z370-A ATX Motherboard | RAMCorsair Vengeance RGB 16GB (2 x 8GB) DDR4 3000MHz | GPU: ASUS Dual GeForce GTX 1060 OC edition 6GB | CASE: CoolerMaster MasterBox Lite 5 RGB | PSU: CoolerMaster V750 | SDD: Samsung 840 Pro 250GB | HDD: Seagate Barracuda  3 TB 7200rpm |  Sound Card: (pending)  | Speaker: Logitech Z623
may be an under volt or too low a pwm signal, it's actually rather dangerous if left as it means the motor cannot keep cool, while unlikely to happen it could cause damage or even a fire but that is an extreme circumstance. maybe go into bios and turn up the rpm's just a tad and see if that cures it.
