Very high cpu temp small overclock!
Go to solution Solved by Avalen,
Don't use Prime95 it's very bad for Haswell chips and potentially also for Skylake. You also might have to turn off adaptive voltage because it might crank voltages too high.
Hello guys, its been a while since i was on the forums and i build a whole new pc with a i7 6700k and be quiet dark rock pro 3.
I tested the stock temps which was 45 degrees so i started overclocking, i startwd with 4.6ghz stock voltage but the temp went sky rocket to 100+, i stopped prime95 instently.
I backed it down to 4.5 ghz and still went way to high, hitting 100 pretty fast.
Then i tried it with 4.4ghz and the temp still went to 100 degrees... now the odd thing is when i put it to 4.3ghz the temp goes way down to 63 degrees (which is still allot since stock is 45 degrees). Ive never seen this before and i dont know why its happening. I use a asus z170 maximus gene motherboard.
I hope you guys got some answers for me
https://linustechtips.com/topic/451602-very-high-cpu-temp-small-overclock/
Arcturus(log here): Intel Core i7 6700K // MSI 980 Ti Gaming 6G(1454/1995) // Kingston HyperX Fury DDR4 2133MHz 16GB //  MSI XPower Gaming Titanium Edition // Samsung 850 EVO 500GB // WD Black 2TB // Corsair 760T // Corsair RM850i
So if i put in manual voltage instead of auto that might fix the problem?
I do not recommend using prime95 it can damage modern Intel CPU's for whatever reason, can make them run 20c+ degress hotter than any other programs
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
It's worth trying.
use intel's xtu
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
Ill be damned!, overclocked to 4.6ghz with manuel 1.285v with intel stress test and its at 64 degress max for now!!! Using intel extreme tuning utility
Thanks all of you
Push it further :D Good luck :)
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
I will!!, just 1 question, i put the voltagr to 1.285v with offset of 0, but when i stress or the voltage goes up to 1.312v, why is that?
No idea. 1.31 is still safe,
Please mark this topic solved. Seems like you found the solution :lol:
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
