spliter with design r5 controller?
Go to solution Solved by W-L,
I checked the web site and it says only 3 on the spliter. :(
You can split one of the lines so it can handle a total of 4 fans if you'd like, but it is only DC voltage control.
There is extra room on the fan controller - you shouldn't need a splitter.  Also, if you add PWM fans you can just set a fan profile in software (or in BIOS).
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
I don't use the included fan controller on my r5.  I prefer PWM fans.
PC Build
Desk Build
Doesn't it only have room for 3 fans? I will be using 4 more than likely.
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
I can check later tonight and get back to you if you'd like.
PC Build
Desk Build
There are only 3 on the splitter indeed.  I contacted Fractal because I planned on running 5 in the NAS (ended up using 6) and considered using Y-splitters to put all the fans on the built-in controller.  They said that while the switch itself could handle the extra load, the wires most likely wouldn't.
I wasn't too sure what to think of that because my SW2 fans are very low wattage, but I decided not to take any chances and put a proper fan controller in one of the 5.25" bays.
This is literally all I wanted to know!
