Hey guys so ive got a rapoo kx wireless mechnical keyboard(love it to bits).
When i connect the usb cable the lights are significantly brighter for about 1 second and then go back to its usual brightness is there anyway i can make the leds go at full brightness.There is only two settings dim and high but high just isnt bright enough
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/
Help!
I don't think you can increase the brightness more, the startup might be over volting or pushing the LED's to 3.4V to get it to flash brighter for a bit until going back to say around 3.0-3.3V. Also it might be the key caps that are causing the dimmness if they don't really let light through.
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051235
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051246
Anyway i can increase the voltage to a constant 3.4v do you think?
Not really you would need to be messing around with the power supply for the LED's, also running them at higher voltages will degrade them faster and in the end make it dim again, you can try one thing which is to make a white paper or plastic backer that goes under the keys to reflect some more of that light up might help.
Kind of like this that are on Razer keyboards:
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051291
Dammit i was hoping i could somehow increase that brightness.Because when it does that bright flash its a really nice even level.Wonder why it flashes for a second when plugged in
Also theres no room to make a backing like that unfortunately
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051305
Probably something in the firmware or chip that controls the lighting unfortunately other than giving it a white backer there isn't much else that can be done. Still it looks like a sweet keyboard I love that brushed metal finish on the front.
Edited by W-L
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051315
It also actually does it when you flick the switch on.but this time it stays bright for a good 3 seconds
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051331
It's a wireless and wired capable keyboard does it go brighter if you plug it in, it might have a power saving mode built in so it doesn't drain itself.
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051344
It doesnt change brightness if its plugged in or not just the same settings.
Its such a good little keyboard but the brightness kind of ruins it.
https://linustechtips.com/topic/451198-modding-rapoo-kx-leds/#findComment-6051358
