So I have no idea where to put this topic so I figured since it related to fans it should be here! My friend gave me the fans that came with his fractal design r5, those 140mm ones. Sadly he lost the screws for them! Does anyone know the threading or where I could buy screws for them?
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
https://linustechtips.com/topic/451028-fan-screws/
amazon or a hardware store, you can alsoget rubber pull through screws.
https://linustechtips.com/topic/451028-fan-screws/#findComment-6047883
https://linustechtips.com/topic/451028-fan-screws/#findComment-6050861
