Long story short, my cousins computer will not boot up anymore. As soon as I turn on this rig, it will show some sign of life but instantly flicker right back off. The fans on the cpu, case and gpu spin for 1 second and then all power is loss. I tried troubleshooting this by plugging in a new powersupply that is confirmed to be working, a new pair of ram, I tried unplugging the ssds and hdds and I still get the same shit happening. This is a rig owned by my cousin and he told me that this started after they had power surge. The only thing that I can't test right now is the cpu since I do not have an extra i7 3770k or a lga 1156 socket cpu.  After doing these tests I still get a little light flicker on the fans and everything else then a shut off. My motherboard is a asus z77 deluxe and it has a green steady light on as soon as I plug it into the wall.Any tips or helpful info will be appreciated.
https://linustechtips.com/topic/450226-pc-will-not-turn-on/
Is the CPU power cable plugged in? I forgot to plug that in when I was building my current rig and it did the same thing.
CPU: I7 4790k  CPU Cooler: NH-D15 GPUMSI 970 4gb   Motherboard: z97 Gaming 5 PSU: Corsair hx850   Ram: Corsair Vengeance 8 gb  SSD: Samsung 850 Evo  Case: Air 540
https://linustechtips.com/topic/450226-pc-will-not-turn-on/#findComment-6036141
Ensure all cables (24pin, 4/8pin CPU, all SATA, and any PCI-e Power) are properly and securely connected. Turn off the power supply and clear the CMOS (reset the BIOS). See if it'll post now.
The instructions for clearing the CMOS for your particular board is here:
Switch off the Power Supply or unplug it.
Simply press and hold the CLR CMOS for a few seconds.
post-81453-0-86487700-1442290774_thumb.p
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/450226-pc-will-not-turn-on/#findComment-6036260
I suspect the motherboard's dead or nearly so. Motherboards are particularly sensitive to spikes in voltage and a sudden spike can cause serious trouble. If the motherboard proves to be indeed dead, when you replace the mobo, plug the system into a surge protector.
https://linustechtips.com/topic/450226-pc-will-not-turn-on/#findComment-6036315
Dead motherboard for sure, check it for blown capacitors on the board like any of these the round top (blown) or even exploded one there blown-capacitor.jpg
Troubleshooting a pc will make you believe in gremlins.
--Thread killer--
https://linustechtips.com/topic/450226-pc-will-not-turn-on/#findComment-6037313
It sounds like a power isue if this dosent fix it and it does the same with a know good PSU the MOBO is Probably dead.
I will do the best I can to help in any way. However I am not all knowing and realize that I can be wrong. If you know something I said is not factual please speak up and provide myself and otters reading reading the thread with the facts proving it. I'm not just here to help others learn I'm also here to learn myself. "An investment in knowledge always pays the best interest." Benjamin Franklin
https://linustechtips.com/topic/450226-pc-will-not-turn-on/#findComment-6039276
Sounds like a cheap PSU allowed the surge to go to more sensitive components.
Clear the CMOS encase its become corrupt. If that doesn't work, neither does a new PSU then I would believe you're fucked in some way.
Check the GPU. You've stated you have no way of testing the mobo / CPU so if one of those are the problem then you'll just have to bite the bullet and get new ones.
It's not a race to the bottom.
https://linustechtips.com/topic/450226-pc-will-not-turn-on/#findComment-6040047
Well it was an EVGA supernova G2 750. If that's considered cheap then damn. I hope my 1000g2 will last and save me from this bs on my rig
https://linustechtips.com/topic/450226-pc-will-not-turn-on/#findComment-6050718
