Hey there LTT community. It's been a long while since I've visited or posted, but I'm hoping for some help.
I built my rig about 1.5 years ago. I've regularly opened it and dusted it best I could without removing fans, radiator, or anything else for that matter aside from case fan filters. Anyway, I recently did a clean windows install, added some storage and did some stress tests as a check up. I ran across some higher temps than I remember when initially dialing in my 4790k to 4.7ghz. I was hoping you could give the screenshot a look and share your thoughts. Should I be focused on package temp vs individual core temps? What about vcore temp? Why am I seeing such large variations between the 4 applications and there temp reports? Do my CPU temps appear to be problematic? Should I check my AIO's fill level?
I ran Aida 64 for 5 minutes for screenshot.
Stressed CPU, GPU and MEM for worst case scenario effect.
My PCs components are listed in full here.
2014 - EVGA 780 SC ACX | 4790K | Asus Sabertooth Z97 Mark 1 | Vengeance DDR3 1600MHz 16GB | RM650 | Be Quiet! Dark Rock Pro 3 | VGA248QE | Fractal Define r4
2015 - EVGA 980 | 4790K | Asus Sabertooth Z97 Mark 1 | Vengeance DDR3 1600MHz 16GB | RM650 | NZXT X41 | Asus ProArt 1080p IPS | Fractal Define r4
2017 - MSI Gaming X 1080 Ti | 6600K | Strix z270e | Trident DDR4 3GHz 16GB | RM650 | NZXT X42 | LG OLED B9 | Dell U3415W | Corsair Crystal 460x
2021 - MSI Gaming X 1080 Ti | 5600X | Strix B550-F | Trident Neo DDR4 3.6GHz 32GB | Dark Power Pro 12 1500W | EK AIO Basic 360 | LG OLED B9 | Dell U3415W | Corsair 5000D Airflow
2023 - Asus TUF 4090 | 5800X3D | Strix B550-F | Viper DDR4 3.6GHz 32GB | RM1000x | h150i 360 Elite LCD | LG OLED B9 | Dell U3415W | Corsair 5000D Airflow
https://linustechtips.com/topic/450195-cpu-temps-assess-diagnose/
In that year and a half, have you flushed your loop to replace your coolant and changed the thermal compound and thermal pads (provided your GPU is w/c'd as well)? Sounds like you might be due for that. Take it as an opportunity as well to get your fans as clean as you can.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
I've an NZXT X41 AIO (140mm Rad) run in push exhaust only cooling cpu. Is it normal to flush, replace coolant, replace thermal paste etc on an AIO 1.5 years after install? Any chance you could answer my other questions? Thanks for taking the time.[emoji5]
With an AIO it's maintenance free so you don't need to change or add fluids, thermal paste after a few years isn't a bad idea since it can dry out, but at around a load of 77C it doesn't seem that bad with a core voltage of ~1.350V on a single 140mm watercooler.
Where are you getting the 77C from?
Just a rough estimate from your current (value) temps on the 4 CPU cores.
Ah, I'm thinking the max temps are more relevant as far as diagnosing a possible problem.
Well your max temps are a quite high at 90C+ but as long as it's averaging that ~73C on the graph your still pretty good. Random spikes can occur at times but as long as they aren't constantly running that hot you should be fine.
Ok, thanks.
So you don't need to blow all the dust out of the fins?  ;)
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
If there is a carpet of dust, well there's your problem! :D
No dust carpet. I regularly air-can the rad, fans, filters, case etc.
Filters.... remove them, remove the brick wall that is the dust filters...
Chernobyl
Kraken
