Hello all! I've owned my Nexus 6 for the past 9 months, and I just started having issues with calling. It seems there is some static in the phone line. I know its not the speaker because whenever I watch a video, its not there. Is it the SIM card? The radio? Or just the carrier having Issues with the phone? (Keep in mind that this issue is consistently reoccurring)
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/449845-nexus-6-calling-issues/
have you tried a diffrent phone to see if its the sim, try factory reset, if not RMA
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/449845-nexus-6-calling-issues/#findComment-6031400
