I found out what the virus I had was, im on vacation away from my pc for 2 more days and im stressed that I might be ratted. My credit card info as well as my steam account is on my PC. After restarting my pc there was no suspicious activity. I have windows 10 could it be immune to RAT? Please help im worried
CPU: Intel i7 4700 GPU: Gigabyte G1 GTX 970 Storage: 1TB Western Blue RAM: 8 GB GDDR3 Operating Software: Windows 10 Power Supply: XFX XTR 550W Case: Shitty HP Case From Old Pre Built PC
<p>
https://linustechtips.com/topic/449283-help/
Sir i will shake your hand for that because why on earth do you put your credit card info onto your computer and no offense only airhead people do that. Anyway, have you run your antivirus full scan yet? If not then you can follow my simple steps to see if you have virus on your PC.
*** Run this without any applications running that includes browser, Steam, or music. *****
1) Malwarebytes Anti Malware - run threat scan
2) AdwCleaner
3) Kaspersky TDSSKiller
4) ESET Online Scanner
5) Emsisoft Emergency Kit
6) Norton Power Eraser
https://linustechtips.com/topic/449283-help/#findComment-6023942
Just turn it off for now until you can get back to it. What was it? And what did you use to remove it?
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/449283-help/#findComment-6023960
I did not remove the RAT i have no idea how
help plz
<p>
https://linustechtips.com/topic/449283-help/#findComment-6024454
help plz
How can anyone help if you don't give info???
What's the detected virus name? Did your AV delete it? Have you run a full AV scan and a Malwarebytes scan? Have you checked for remainders in safe mode? Is that PC connected to other devices (cloud or home group for example)? Have you checked if other people had the same problem?
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/449283-help/#findComment-6024884
help plz
I can't help unless you provide some basic information, like what the name of what the virus was and what you used to remove it.
https://linustechtips.com/topic/449283-help/#findComment-6025379
it was called inject.exe and to remove it i put in trash bik when i get back i try to install malwarebyte but i cant anymore it gives me an error
it was called inject.exe and to remove it i put in trash bin when i get back i try to install malwarebyte but i cant anymore it gives me an error
<p>
https://linustechtips.com/topic/449283-help/#findComment-6025755
What error
https://linustechtips.com/topic/449283-help/#findComment-6025767
What error
not at home atm i made a restore poont before the virus will it work?
<p>
https://linustechtips.com/topic/449283-help/#findComment-6026272
Maybe, but you should run a scan with malwarebytes first.
https://linustechtips.com/topic/449283-help/#findComment-6026402
Thank u!!!
<p>
https://linustechtips.com/topic/449283-help/#findComment-6026425
comodo cleaning essentials is also very good and HIjackThis is fantastic for getting rid of some real nasties but requires you to learn to read the logs.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/449283-help/#findComment-6029167
If a RAT has got on your pc, if its not a basic trojan then that means either your targetted or your a part of a pretty serious botnet.
Disconnect from any internet, this means no applications or any programs on your computer can connect to the internet,
And then either completley wipe windows, or use a good removal tool, except most RATs are custom made and aren't gonna be detected (unless it was a kiddie script).
Lets just hope the attacker hasn't put a bios level backdoor in there.  If they have.  Your screwed. (very rare though)
https://linustechtips.com/topic/449283-help/#findComment-6029442
AV Tools are good to detect a Virus, but to remove them, there is only one trustworthy way. Reinstall your OC.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/449283-help/#findComment-6029879
