Is Transparent Red by Samsung, viable?
Hello everyone. I've gotten my PC up and running, and it's running perfectly. I am looking for a monitor because I'm using my TV right now as a temporary solution.
Here's what I need the monitor to be:
Size: 24" or above (my iMac 21.5" 1920x1080 is a bit too small for me. I find that I wish it was bigger on a daily basis)
Resolution: 1920x1080 I will not be getting into the 1440p yet. For this monitor I want a 1920x1080.
Features: HDMI input. LED backlit. 5ms or 2ms response time is fine. Nice sturdy stand, maybe even adjustable.
My good friend recommended the Samsung Transparent Red 27".
http://www.samsung.com/us/computer/monitors/LT27B350ND/ZA
Now, I think he's getting it to me at around $350USD.
My budget on this monitor is $400 including shipping.
What could you recommend that's better, a better value, or has more features for the same price? I'm really looking forward to your input as Samsung thinks that their Transparent Red is the best on the market. LOL
Thanks in advance. Oh yea, here's my current build.
Keep in mind that my RAM is the same as what I put on PC Part Picker, except I have 8GB (2 4GBs) but they didn't have that option on PCPP.
I don't think that is the best panel in the market. Get a Asus PA248Q for around 270$ or PB238Q for around 180. PA248Q is 24 inches and has a resolution of 1920 x 1200. It's the sweet spot between 1080p and 1440p. Also it's an IPS panel and has awesome colors plus come factory calibrated.
PA248Q - This one is a newer version
PB238Q - This is only 1080p and does not come factory calibrated.
IF YOU HAVE THE BUDGET OF 550$ THEN GET A 27 inch 1440p
