Hi,
I want to change my drive letter on my hard drive from D to something else, as I think some of the paths have been corrupted. First of all, will changing the drive letter help with that? And secondly, it says if I change the drive letter some programs might not work. If some programs don't work after changing the drive letter, can I revert back to the letter D again without any problems?
I have attached two screenshots of my problem.
post-194784-0-59236600-1442051462_thumb.
post-194784-0-13194300-1442051468_thumb.
Desktop: Processor - Intel Core i7 5820K   Motherboard - Gigabyte GA-X99-UD3   RAM - Crucial Ballistix Sport 16GB 2400MHz DDR4   GPU - Gigabyte GeForce 980 Ti G1 Gaming 6GB Case - Fractal Design R4 Window   Storage - x1 WD Green 1TB, x1 WD Green 2TB, x1 Samsung 850EVO 120GB, x1 Kingston SSDNow 120GB  PSU - Cooler Master B700 (700W)   Displays - x1 Dell E2214H, x2 Dell 1908FP-BLK   Cooling - Noctua NH-D14 SE2011
Keyboard - Razer Blackwidow Expert 2014   Mouse - Razer Deathaddder 2013   Speakers - Logitech Z906 5.1 OS - Windows 10 Pro   Headphones - Steelseries 9H, Sennheiser Momentum
https://linustechtips.com/topic/448449-changing-drive-letter-on-storage/
I'm pretty sure drives C and D are both hard coded into the OS. C for system files and D for an attached disk drive. All others (including A and B ) are fair game. It might be possible though, and the only reason programs wont work is that they lost their old directories.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Maybe, and yes.
Ok, thank you for the reply.
Could you elaborate in any way?
on what exactly?
on what exactly?
How is D hard coded to the OS? And any way to create new directories?
None of my drives is called D
Why don't you add these files again to your music library?
The problem is that my D drive in some places isn't called d anymore. It is renamed \\?\Volume{D8A52AE3-628C-11E4-8C69-806E6F6E6963}\Files\Music. But if I put the files in there again you think it would help?
I mean like how the C drive is always the drive or partition that windows is installed on the D drive, by default anyway, is for optical disk drives (CDs, DVDs, Blue Ray, ect)
I'm guessing you don't have a CD/DVD drive
WHOA, Ok I've never heard of that happening before.
I have a optical disk drive, I have manually named it G:
I just tried. Same error message as the first pic I posted.
Yeah, thats my main problem. I asked a friend that has some experience with computers. He said he didn't ever encounter that before either. Thats why I am writing on this forum. Might be a rare problem.
