1. Refined version of bedbug, dropped the PSU from 1250watt platinum, to 600watt bronze, then to a raidmaxx for the blue lighting (forgot the watts) then finally to a blue lite psu made by rosewill BUT its 1000watt and bronze, quite honestly long as its not raidmaxx i feel a bit happier on its reliablity factor.
1a. 1TB SSD dropped to 500GB SSD
1b. memory was changed to one, then realized that one is incompatible, it is now 16GB, the first memory was 32GB then refined down but going down.
1c. added optical drive once i realized disks for say cisco routers will be needed to be put into something lol
1d. monitor went from 4k overdoing to a 24inch 1ms 60hz widescreen 1920x1080
1e, Pretty sure the CPU Cooler will need to be changed to something else, but for now its been remained as the original listing for that, anyone have an idea for it?
2. I am also making an AMD BedBug list for a side-to-side comparison of performance to cost is it worth it to get AMD OR get Intel is what it will come down to.. and right now im leaning "Intel BedBug" because well.. its the first original list and that alone earn respect BUT also because well... i cant find a micro ATX board for the  new AMD FX 9590 with a whopping 4.7ghz, and thats whats really holding me back on the AMD side, intel side its only 3.3 ghz BUT its better than what I have now, and thats what matters, to me, if i could push for a system with nearly 5ghz from factory that would be nice... but.. i need a board for that... so yea.. anyone in LTT terroritory willing to help me figure this out?, I can not find a micro atx (not ruling out itx btw, i dont care between itx and atx, but atx i thought will be easier to find) anyways.. yea, cant find a micro atx board for the 4.7ghz cpu and im not big into AMD so i dont know what their 2nd fastest chip is either.
3. Here is BedBugs current list, can anyone help refine it down? (keeping rosewill 1000w psu even though i need far less because well... BLUE, im going black blue theme and for Intel BedBug it has less blue than AMD BedBug so far because the case alone on AMD BedBug is BitFenix M Cobalt Blue) http://pcpartpicker.com/user/CODEMaster00/saved/#view=qmKD4D
4. Does BitFenix M Cobalt Blue mean any difference between BitFenix (no M) Cobalt Blue?, I heard it was M allowing a normal ATX board .. is that true? if so it solves the AMD BedBug issue.
https://linustechtips.com/topic/447807-refined-bed-bug-and-questions/
