is it a good build with these specs i am planning to do it
 i7 4790k
corsair h100i
hyperx savage 2 x 240 gb ssd at raid 0
2 tb harddisk
r9 390 saphire nitro
16GB 1866 RAM
MSI GAMING 5 MOTHERBOARD Z97
COOLER MASTER STORM TROOPER CASE.
GIVE YOUR SUGGESTION ANDS PLEASE HELP ME IT .
https://linustechtips.com/topic/447547-help-me-with-the-build/
 i7 4790k
corsair h100i
2 tb harddisk
16GB 1866 RAM
  1. if you're gaming, go with the i5-6600k with an asus z170-p motherboard. if you want sli, get the z170 pro gaming
  2. make sure you get the h100i gtx as it has a new design. you could get away with a nh-d14 which is cheaper or the Phanteks PH-TC14PE_BK
  3. 8gb of ram is sufficient for gaming
  4. i would get the msi r9 390 as it overclocks very well compared to most other 390's and it's NOT voltage locked
  5. get an evga b2, g2, or gs psu
BigDay
https://linustechtips.com/topic/447547-help-me-with-the-build/#findComment-6000591
Why do people keep posting build requests in the General Discussions subforum. Do they not scroll down and actually read the names of the subforums?
New builds and planning...
And basically what @BigDay said + get a WD HDD. And I've read that HyperX SSD's are not that great (or atleast some models, somebody verify on this).
It is said, that civilised man seeks out good and intelligent company, so that through learned discourse he may rise above the savage and closer to God. Personally, however, I like to start the day with a total dickhead to remind me I'm best!
https://linustechtips.com/topic/447547-help-me-with-the-build/#findComment-6000611
BRO IT IS 110 DOLLARS PRICIER THAN THE SAPHIRE ONE
https://linustechtips.com/topic/447547-help-me-with-the-build/#findComment-6000907
