Help Overclocking
Solved by -rascal-,
How do I know if its unlocked? And if it isn´t, how do I do it?
All the CPU's in the current FX line-up have a unlocked multiplier -- back in the day, only select CPU's had an unlocked multiplier, and are labelled as "Black Edition."
Given that you are overclocking via AMD OverDrive, Windows based software overclocking, I suggest that you do some reading up before attempting to overclock your FX-8320. I looks like you have very little to no experience in CPU overclocking.
I may be "old school," but I think many here as well, but it is always best to overclock via the motherboard BIOS...and not through software.
Here are some suggested reading regarding to overclocking FX-81xxx and/or FX-83xxx Processors:
- http://www.overclock.net/t/1140459/bulldozer-overclocking-guide-performance-scaling-charts-max-ocs-ln2-results-coming
- http://www.overclock.net/t/1434322/amd-multiplier-overclocking-guide-vishera-bulldozer-phenom-more-ga-990fxa-ud5-rev1-1-non-uefi-bios-example
And...some overclocking tips:
- On air cooling, it is advised not to go above 1.500V on the Core Voltage
- Since the FX-8320 has an unlocked multiplier, the simplest way, especially for a beginner, is to overclocking by adjusting the CPU Multiplier
- Gradually increase the Core Voltage -- DO NOT just crank it up to 1.500V
- Increase your overclock by a small amount (i.e. bump the multiplier up by 1X), and test for stability
- For stability testing (just to name a few), use AIDA64's built-in stability test, 3D Mark, and/or Cinebench. Prime95 is okay for AMD CPU's, but you still need to be careful with it regardless. I am still unsure about CPU-Z's new built-in "CPU benchmark" / stability tester.
- To monitor temperatures, you can use HWMonitor, AIDA64, Speccy, etc. AMD OverDrive is acceptable as well (use the thermal margin -- how much you have left before reaching the maximum safe operating temperature)
- CPU-Z and GPU-Z should be some of the programs on your "PC tool belt"
