Just a quick question concerning the usage of Corsair h100i while overclocking.
If one plans to change the voltage and multiplier, ie - overclock - do you need to switch the h100i profile to Balanced Mode or even higher?
Asking because both of those are much louder than Quiet mode (obviously).
So why overclock if I'll need to have the cooler make more noise than I'm comfortable with? Do others keep their coolers at faster RPMs just to maintain good temp on the overlocked CPU?
Perhaps just overclock this CPU to such an extent that Quiet Mode will keep temperatures below 60 (generally accepted load temp for this CPU)?
It's a question I had for a while now ... do people really tolerate the noise just to enjoy the overclock?
CPU R7 3800X    Motherboard Asus Prime X370 Pro  RAM  24GB Corsair LPX 3000 (at 2933Mhz)    GPU EVGA GeForce RTX 3070 XC3 SC  Case Phanteks Enthoo Pro M
Storage 1 x 1TB m.2 (Windows), 1x 500GB SSD (Linux Mint), 1x 4TB SSD (for data Samsung 870) PSU Corsair RM1000  Cooling deepcool ak620(? probably)
Synology NAS 2 x 8TB
https://linustechtips.com/topic/447149-quick-question-on-oc-using-h100i/
I am a heavy CPU user but I rarely even run my i7-3930K hard enough that OC would give anything extra. So I keep everything silent and hop quickly to BIOS  to turn the OC and turbo cooling on if I ever need it. Can't even remember when I did it last. Maybe I should some day check if it's still stable... IMHO if you're not capping the CPU in normal use at stock, silence outweighs OC any time.
Well, if it's louder than you want it to keep it at a temperature you're comfortable with get some better fans as the stock corsair fans suck
Good idea, making a note to check up on this.
Unfortunately i'm using a Phenom II x4 965 which is ok on single heavy tasks - but when I'm working hard and enjoying a nice heavy load - it really like the 100% load mark and doesn't let go :(
What's so special about them - besides the noted "quietness"-so to speak.
Oh. Phenom II is hot AF. :D Temps are more of an issue for you than me anyway. :F
You could say Phenom'enaly hot? huehuehue
Mine stayed at 60C for 2 years because i forgot to lower the voltage as I did the multiplier after a bout of OCing back then - and didn't feel anything bad. Good performance. Dunno why people say 60 is max (i had 60 on IDLE).
Anyway - looks like quiet mode and reasonable OC is the way to go.
And made a point to check up on better fans to replace stocks.
they're quiet with good static pressure
Alright. Any more variants that come to mind? (asking because CRYORIG aren't represented in this area and ebay asks $60+ each).
PS: If other ones are that silent - i might put 2 to front and 2 back and still use Quiet mode. Though I remember watching a Jayz Two Cents video showing it might not be as effective as it seems ....
Preliminary decision is 4x Arctic F12 in a push-pull configuration. Cheap and ok reviews.
