Hey guys!
I just want to make sure if I'm doing this right. I am building first "custom build" PC (#hyped).
So here are the components:
I already own kinda new HDD so there is no need for new one.
Thanks for the answers !
https://linustechtips.com/topic/447118-custom-build-pc/
These are nice parts. For an AMD system they are very good and in general, a quality choice. Although I'd suggest that you get an SSD for boot and a new HDD for storage, since old HDD'd tend to fail more easily than the new ones. If you feel OK to use it go right ahead, but an SSD for boot is a must these days.
https://linustechtips.com/topic/447118-custom-build-pc/#findComment-5993908
What country are you in for retailers
Slovenia, EU.
Thanks. I was thinking about that too. I would buy SSD later on.
https://linustechtips.com/topic/447118-custom-build-pc/#findComment-5993941
Hey guys!
I am sure there are much better builds than this one.
My i5 6500 is bad and can't even maintain 4.5ghz, and 4.4ghz causes it to slowly become unstable over weeks with a vcore of 1.395. FML
https://linustechtips.com/topic/447118-custom-build-pc/#findComment-5994032
Since in europe prices tend to differ, here is what you should have in mind
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  (€113.28 @ Mindfactory)
Motherboard: Gigabyte GA-B85M-D3H Micro ATX LGA1150 Motherboard  (€67.91 @ Amazon Deutschland)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  (€48.08 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€55.93 @ Mindfactory)
Video Card: PowerColor Radeon R9 280X 3GB TurboDuo Video Card  (€179.90 @ Mindfactory)
Case: Corsair 100R ATX Mid Tower Case  (€55.49 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€78.30 @ Mindfactory)
Total: €598.89
Generated by PCPartPicker 2015-09-10 01:02 CEST+0200
The site has changed....
https://linustechtips.com/topic/447118-custom-build-pc/#findComment-5994301
Total: €598.89
I can't find R9 280X in local store
https://linustechtips.com/topic/447118-custom-build-pc/#findComment-5997113
