Also.. YAY!! "Bed Bug" 's build design is complete... so far..
Okay so, I made sure the board was compatible for a SATA 3, and a the graphics card,
I made sure the power supply can out perform itself (I still don't know what i NEED as far as power supply goes, so i think i just overkilled it, let me know please if you want to, im also actually afraid i might not having enough power but yea.. plis help) ,
I made sure to find a case with 2 fans, made sure to find a cpu with the fan and heatsink (im still putting an "aftermarket (whys it called aftermarket?) in my shopping cart though just in case the stock is horrid or cant let memory fit,
I made sure to get as much memory as supported and not more, but still find a board with enough slot so I can re-use it if so desire
I made sure to find dimensions in inches and mm for the PSU and video card and heatsink BUT still unsure if it can all fit..
other thing is .. Can any find a black and blue case (or fans for that matter :P) if this case doesn't let everything fit? I'm also worried it isn't enough cooling, can someone let me know?
Here is the list: (for some reason "spoiler" isnt part of UI post format, and i don;t know the code for it so.. bear with a list, also cough cough guys, its not an oversight nor a design flaw, but hey, convenience.)
Case; which is a big thing im worried about having fit everything: http://www.newegg.com/Product/Product.aspx?Item=N82E16811353073
Video Card; http://www.newegg.com/Product/Product.aspx?Item=N82E16814500379 will this get enough cooling, also will it fit?
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817379029 yea uh.. I need to know if it will fit, and also, just because it can do 1250 watts, will it be taxing the light bill as if im USING that much watts?, or do i pay for what i use? aka most likely not the entire 1250 watts.
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131836 most importantly, will it fit? i THINK it will, but 2ndly, will it fit a heatsink ...
Heatsink: http://www.newegg.com/Product/Product.aspx?Item=N82E16835230047 will this fit on the motherboard with this memory ...
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231569 will this and the prior mentioned heatsink fit all together and not get in the way??, also does the prior mentioned video card cause any memory/RAM fitting issues? just as well will it be cool enough (using the factory overclock, i dont try to OC because I dont want to drop bank on the power bill to keep stuff super cool, or even to use that much power., also anyone know how much this would caus for wattage then how much it would translate into?)
https://linustechtips.com/topic/447055-first-build-compatibility-need-to-know/
PCPartpicker.com has some compatibility checkers. Use that website for plan/building. It's very handy since it also has price checkers on multiple e-tailers.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
PSU is VERY overpriced. You don't need more then 1000ws. ( even that's overkill but will allow for SLI and big overclocks along with future upgrades )
Look into EVGA PS T2 or P2
Any XFX
Any SeaSonic
Any SuperFlower
Other then that use PCPartPicker
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
This is the CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115073 WAS gonna go crazy baller for the "devils canyon 4ghz" BUT this can get to 3.7 from factory so "close nuff' lol, and it fits the board which is most important for the card and SSD factors.
Full List of parts (can anyone reccomend thermal compound and a good static strap?? sorta new to this so i dont have any of those from any previous builds like most people would.)
Anyways...
CPU heatsink (will only put on if the stock is super bad or wont let the memory fit): http://www.newegg.com/Product/Product.aspx?Item=N82E16835230047
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231569
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817379029 (will this fit the case too???, might be changing it, but if this can fit i might not need to ask about a PSU with less watts and smaller size)
SSD: (plan to make this be boot drive, but its only memory that i have that wont be for RAM... so... do i have to do anything in order for it to be boot drive or will it go there default?) http://www.newegg.com/Product/Product.aspx?Item=N82E16820147362
Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814500379 (how does the DDR5 memory work that comes on this, is it memory for graphics or what?? i feel stupids :P)
AND the problem causer of all this... http://www.newegg.com/Product/Product.aspx?Item=N82E16811353073 will this case fit everything is the biggest issue, thank you for help.
