I'm confused and need help.
Does a dac just get rid of static or does it do other things as well and what is the difference between a dac and an amp?
A DAC is a digital to analog converter. Meaning it can translate computer signals (digital) to heaphone signals (analog). The hting that causes your static is the quality of the DAC built into your motherboard, as well as interference from other electrical components in your PC case. If you use a USB DAC, that interference is gone. A bad DAC will mean bad sound but these days most external DACs or soundcards will be just fine.
An amp stands for amplifier and amplifies the signal to a useable level. a USB DAC like the Fiio E10K has one built in so is technically an amp/DAC combo unit. Any soundcard or standalone USB DAC should have one and unless you use VERY high end headphones ou shoul never really see a problem with the amp that is used.
