System won't post
Go to solution Solved by nzstubbies,
I managed to find the error, it was a compatability issue between my usb3.0 to usb2.0 adapter.
Thanks for the replies though
I am building a NAS and I am using a Supermicro X7SPA-HF-D525 motherboard. The system will start and all my fans as well.
It will not post and gives me a beeing error that correspones with a memory error. I have checked it is the correct memory and and have tried a 2gb and 4gb post (as 4gb is the max) with it still giving me the same error beep. I tested the memory in an old laptop and it booted and the system showed 4gb installed.
Any ideas on what else I could do to get it to post?
I am using a silverstone SST-SX500-LG powersupply
The Chassis is a silverstone DS380
Thanks in advance
https://linustechtips.com/topic/446680-system-wont-post/
Thanks in advance
Is it non ecc memory?
MOBO- MSI z97 gaming 5  CPU- I5 4690k   GPU- G1 Gaming gtx970  RAM- 16gb Corsair Vegeance  PSU- Corsair RM650  COOLING- Corsair H110iGT
STORAGE- AMD r7 120gb SSD / 500gb HDD  CASE- Phanteks Enthoo Luxe   Sound-  Logitech z506 / Corsair Void  Peripherals- G710, G502
https://linustechtips.com/topic/446680-system-wont-post/#findComment-5987461
What is the error code specifically?
Processor Intel Core i5-4690K CPU Cooler Cooler Master Hyper 212 EVO Motherboard MSI Z97-G45 RAM 8GB G.Skill Ripjaws X Storage Samsung 850 EVO 250GB SSD WD Caviar Blue 1TB HDD Graphics Card EVGA GeForce GTX 970 Case NZXT Phantom (Black) PSU Corsair CX600M Operating System Windows 10 Monitor BenQ GL2760H Headset Skullcandy PLYR 1 & Sennheiser Momentum
https://linustechtips.com/topic/446680-system-wont-post/#findComment-5987481
