hello, im running my pc and was tinkering in the bios and found out that i an use my igpu for using dual monitors.
i enabled this, set a vram amount for the onboard and set up my second display connected to the motherboard.
i booted my pc, the main screen wallpaper is now black and i can see the 2nd display in settings, but there is no image
how do i setup dual monitors? thank you!
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/445489-dual-monitors-help/
what os are you running?
windows 10
Rigs I've Built
https://linustechtips.com/topic/445489-dual-monitors-help/#findComment-5970113
