Hey people!
I'm worried that the GALAX GeForece GTX 970 HOF will not fit in the NZXT H440W case that i'm planing to buy.
It stats the following in pcpartpicker: the NZXT H440 supports cards up to 406mm long, but the video card is 308mm, some drive bays may not be usable.
is it possible that the video card is to wide too?
I dont mind that some drive bays are not usable.
https://linustechtips.com/topic/445392-need-help/
It will fit.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/445392-need-help/#findComment-5968463
