Hyper 212 evo question
Go to solution Solved by Compgeek,
Mine moves and i had no issues. I'd say it's normal
Should it be able to rotate slightly when I twist slightly on it?
It's not easy, but not a light force either.
All temps seem normal for it though.
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/445243-hyper-212-evo-question/
If you do that you have a chance of breaking your thermal paste, but yes it's possible that you can move it slightly, the screws are stopped by springs after all!
https://linustechtips.com/topic/445243-hyper-212-evo-question/#findComment-5966525
