I have just put together a new build and I am trying to get it to run. When I turn it on all of the fans and lights go on but my monitor says it isn't getting any signal. Every wire is plugged in but is there something I am missing?
https://linustechtips.com/topic/444767-help/
Does it have a dedicated GPU? Are you using the GPU? If you are using the GPU, try to plug in the cable onto the motherboard I/O port (if it supports it)
Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming Intel Core i5 3570K (4.4Ghz @ 1.4v) CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2
https://linustechtips.com/topic/444767-help/#findComment-5960494
Ya I tried that already and still nothing
does the Monitor have multiple inputs?
https://linustechtips.com/topic/444767-help/#findComment-5960514
Yes and I tried both of them
Did you try different cables? Also, did you change the input for the monitor?
https://linustechtips.com/topic/444767-help/#findComment-5960537
Yes and yes
Do you have another computer to try the monitor on?
https://linustechtips.com/topic/444767-help/#findComment-5960557
are all the wires plugged in correctly?
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/444767-help/#findComment-5962478
