Hey I have recently built a computer for a friend who was in despite need of one and this afternoon I added a new fan to the front of the case so it has some air flow coming in from there. It is an Antec One case and now it refuses to register the power button at all.
I think this might be form the fact that I had to remove a ground strap to be able to move the front panel out of the way. But it could also be form the fact that I saw that the 24 pin was not seated right in the mobo (an Asus M5A97 LE RV2) so I gave it a push to seat it properly.
I know he has more then enough power for the rig, as we had it running last night and installed Windows 7. So this bothers me.
I just hope that I did not short out the board by putting the 24 pin in properly. Cause if I did I will be buying him a new board out of my own pocket.
Thanks for any help that can be given, even if it's just a bop to the head cause I missed something stupid.
https://linustechtips.com/topic/444722-no-power-situation/
Did you ground yourself before touching the hardware?
https://linustechtips.com/topic/444722-no-power-situation/#findComment-5959871
Is the plug for the case power button is properly connected and not loose?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/444722-no-power-situation/#findComment-5962243
  • 4 weeks later...
