My friend has the following system
CPU: Athlon 64 X2 3800+ 1.9 GHz dual core
RAM: 3GB DDR2
GPU: Nvidia 9600 GT
Here's chivalry's system requirements - would he be able to run it @ 1280x1024 res? thoughts?
  • OS: Windows XP
  • Processor: Intel Core 2 Duo 2.4 GHz or AMD Athlon X2 2.7 GHz (a dual-core CPU is required)
  • Memory: 2 GB RAM
  • Graphics: ATI Radeon 3870 or higher, Nvidia GeForce 8800 GT or higher. 512MB VRAM.
  • DirectX®: 9.0c
  • Hard Drive: 7 GB HD space
  • Other Requirements: Broadband Internet connection
  • Supported controls:: Keyboard + Mouse, or Xbox 360 controller, Xbox One controller, or compatible XInput controller
https://linustechtips.com/topic/444505-input-on-system-requirements-needed/
Should run fine, may have to tweak everything down.
CPU: i7 5820K @ 4.00GHz Mobo: ASUS X99-DELUXE LGA 2011-v3RAM: Corsair LPX 64GB Quad-Channel DDR4 @ 2400MHzGPU: GTX 970 x2 SLI | Storage: 250 GB AMD SSD x 4 Raid 0
I was slightly concerned about the CPU - i know the specs they post are for 1080p so I imagined it could run but still wanted more opinions before dropping cash on it.
I think it would run fine. Low settings probably, at that resolution you might get over 30fps.
i7 6700K - ASUS Maximus VIII Ranger - Corsair H110i GT CPU Cooler - EVGA GTX 980 Ti ACX2.0+ SC+ - 16GB Corsair Vengeance LPX 3000MHz - Samsung 850 EVO 500GB - AX760i - Corsair 450D - XB270HU G-Sync Monitor
i7 3770K - H110 Corsair CPU Cooler - ASUS P8Z77 V-PRO - GTX 980 Reference - 16GB HyperX Beast 1600MHz - Intel 240GB SSD - HX750i - Corsair 750D - XB270HU G-Sync Monitor
Low settings, yes.
I love the game btw :)
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
