I am totally oblivious to coding and game development. I know the basics like how textures work, etc stuff that most gamers know... That said I have a question. I just got Metal Gear Solid 5, its a fantastic game but I was a bit disappointed because I recently got a new 144hz gsync screen and the frames are locked at 60. First world problems right.
Every so often a series or game comes over from console and this seems a trend, MGS 5 has locked frames, Dark souls 1 had locked frames, 2 is locked at 60 I believe. And every time when I search to see if you can unlock frames I am met with the same reasoning... the game developers tie the physics to the frames/frame rate. Which seems odd but after playing Dark souls 1 and uncapping the frames with a mod weird stuff starts to happen, you can no longer jump as far and can fall through the world in some spots etc.
So why do they do that? From my perspective even before I had the screen it seems limiting especially for the PC platform (I realise some of these games came to PC as an after thought but DS 2 and MGS were going to come to PC from the start). I am guessing its to do with ease and time restraints, consoles games are developed to run at a certain frame rate and so tying the physics to frame rate seems like a consistent way to do it. Just wondering if someone in the know can explain it too me.
Not sure if this is the right place but I decided to post general is it didn't seem to fit into the PC gaming section.
https://linustechtips.com/topic/444262-game-physics-and-frame-rate-question/
Maybe mojority of gamers own 60hz panels. Or they didnt think it was worth it. 144Hz is more for FPS players
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
Yea, I get that part but was wondering if the old reason they tie physics to framerate is true? and if so why? I am honestly fine with the 60fps its a great game and well optimized, but it got me thinking and I wanted to know for once and for all. Maybe when building a game engine allowing high frames i.e. over 60fps has to be there from the start, and its not about tying physics to frame rate as much as allowing the engine to run that fast does weird things because it was never designed for it.
Because lazy programming. Just like graphics, physics is calculated in 'frames'. It's much easier to force a game engine to run physics calculations at the same rate as graphics calculations, because it guarantees that they are in sync and being calculated in the right order. If calculations are not run in the right order you get audio bugs, graphical bugs, and physics bugs because they are all interdependent. Out of sync calculations are how you get stuff like this: U6qCoXb.jpg
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
