Hey guys my parts are arriving! although I won't be having my psu and hdd. I was thinking of getting it to run with my old psu and hard drive.
My old desktop is the "optiplex gx520" and here is my build http://pcpartpicker.com/p/4bhJ4D. My power supply says the max output is 220w and pc part picker says its 137w for my build . Here is the model name for my old psu n220p-01       http://www.amazon.com/Genuine-Optiplex-Systems-Dimension-Numbers/dp/B001G42HIW. So I was wondering of installing it into my system for a few days and then getting to new psu. But i am not aware of the risks I face when installing it. Also can i just run linux of a usb flashdrive instead of a hdd in time for when i get windows 8.1.
Thanks!
https://linustechtips.com/topic/444228-using-old-psu/
It will be fine for a short while, but not as a long term solution. And yes, you can create a live Linux USB.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/444228-using-old-psu/#findComment-5953878
I'm going to strongly suggest against it. OEM PSUs are not known for their quality, and its also worth noting that the computer you listed is from the time when Dell was using BTX motherboards and proprietary connectors. Is it possible that it will work perfectly fine? Absolutely. But there is also a possibility of a computer shaped fireball.
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
https://linustechtips.com/topic/444228-using-old-psu/#findComment-5953914
How about just one boot up for testing if my components work?
https://linustechtips.com/topic/444228-using-old-psu/#findComment-5953932
Absolutely. I ran my a10 7850k system (about a 170 watts) on a LiteON 220 watt unit. It was about 8 years old from an emachines 1300. Having several PC's from the 80's I would trust an OEM PSU over anything you could buy They may be ugly but the quality is amazing. OEM PSU's are almost always better then one bought seperately.
https://linustechtips.com/topic/444228-using-old-psu/#findComment-5959541
That's not even remotely close to being accurate. Most OEM PSUs these days (that are used by Dell, HP, etc...) are utter crap.
PSU Tier List | CoC
https://linustechtips.com/topic/444228-using-old-psu/#findComment-5959605
Yea...HP sells millions to thousands of retail outlets and they are always failing. IBM PS/2's and 5150's still have working power supplies after 35 years of constant use. The average HP or Dell PSU is better then anything you can buy, they simply never die. Show me a corsair(or any other) PSU that has never been turned off in 10 or 20 years.
https://linustechtips.com/topic/444228-using-old-psu/#findComment-5959672
As someone who has worked in IT, that's a bullshit statement. I interned in an IT department for a company of about 150~ employees, and in the two months that I was working there I had to replace about 5 PCs all of which had a failed PSU. Only one of the computers I had to replace had a failed HDD.
Also, companies from 35 years ago used MUCH high quality components for their OEM designs. Nowadays it's all handed out to the cheapest contractor, regardless of what kind of components are used.
PSU Tier List | CoC
https://linustechtips.com/topic/444228-using-old-psu/#findComment-5959716
