Hi guys I have sli 980ti's and my top card hits 83 degrees is this normal and is there anything I can do to help it,
I was considering making a metal plate to fix to my case to separate the cards do u think this would help ?
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/444090-sli-overheating/
Because the top,one is trying to suck air in. Try and find a way to get fresh air in between the cards and that'll help.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951781
Get a mobo with space between the slots. If the fans are at max and you are still reaching 80+ then is also a case airflow problem.
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951794
The temperatures are normal for reference 980 Ti's.
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951804
I have msi twin frozen ones
I have a 750d with noctua fans in every space so air flow isn't bad
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951836
Especially since its the top card in an sli config
There's not reference there the msi ones
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951844
82*C for a 980 Ti is normal - those reference cards run @ 85*C
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951848
It's not reference so is it to high or is it ok ?
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951856
How is the airflow in the case?
I have a 750d
All fan slots are filled with noctua fans
2 intake in the front
2 exaughsst on my h110 on top
Exaughst in rear
1 intake in the bottom
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951866
it's ok - I was saying that reference cards ran at that temp, be it SLI or not.
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951867
I have a 750d
Exaughst in rear
I mean the temps aren't high enough to damage anything. They'll just limit your boost clock. What's the temp of bottom card?
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951873
ok thanks
My bottom card runs at 70 tops and the top 84
But when I had one card it maxed at 77
I'm well confused
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951876
bottom card is 70
And they boost up to 1340 MHz
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951885
Shouldn't worry about it then.
Ok cheers
If I limit temps in msi after burner to 77
They boost to 1160 MHz
Would that be better or leave then at 1360 at 83 degrees ?
Btw this is only playing witcher 3 ultra 4k
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951903
ok thanks
I'm well confused
Silicon lottery - the top one also intakes warmer air.
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951905
Ok cheers
You'd be losing performance over nothing. 83*C is fine. Titan X Runs at 87*C regardless of anything.
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951908
Should I swap them around see if It's any better ?
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951910
ok thanks :)
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951915
It's not an issue - as soon as it gets to 90*C then you can start panicking and invite me for a barbecue.
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951920
Aha we shal cool burgers on the top one and stake on the bottom ?
also (1600)
https://linustechtips.com/topic/444090-sli-overheating/#findComment-5951924
