Ay, I just installed my new thermaltake smartpower 750w, and after about 5 minutes of being turned on and running fine, it will just shut off and two seconds later turn back on? It keeps doing this over and over, I have everything plugged in correctly.
- CPU: Intel i7 3770 - GPU: MSI R9 390 - RAM: 16GB of DDR3 - SSD: Crucial BX100 - HDD: Seagate Barracuda 1TB -
https://linustechtips.com/topic/443722-psu-help/
What are your computer specs? The PSU may not have enough power to run it properly.
Guide to GTX 900 Series: http://linustechtips.com/main/topic/457526-nvidia-900-series-basic-performance-guide/
Performance expert, building noob.
There is no such thing as excess in hardware.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946707
My gpu is coming next Monday, I've got a 6780 in it at the moment. 750w is overkill for that
Yep, you're right.
I did some research into your PSU and it looks like there are a noticeable amount of duds in the bunch. Since you already checked the wiring in your computer, I'd suggest calling the company and telling them your problem. Luckily those things come with pretty long warranties so you'll be able to get a replacement.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946723
Yep, you're right.
Shiiet, well thanks. Is it possible that the wire to the on connecter to the mobo could be in the wrong position and cause something like this? I did notice turning it on with the power switch worked but not turning it off with the switch?
https://linustechtips.com/topic/443722-psu-help/#findComment-5946746
There's a chance that's the problem. I'd suggest looking at your wiring again then attempting to run your PC. If that doesn't work, then it's best to just call the company and get a replacement.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946760
If I can't fix it I'll be taking it back and be getting a CX600M.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946767
Sounds like a good bet, although it's not exactly smart fiscally. Just make sure your computer only needs 600W  :P
I had one of those on my old computer and didn't run into any problems.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946772
Sounds like a good bet, although it's not exactly smart fiscally. Just make sure your computer only needs 600W [emoji14]
Re plugged the on off wires, still restarts every 5 minutes.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946806
Sad to hear  :(  I hate getting defective PC hardware, I know that feel bro.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946807
Ok um I turned it on again and all the usb ports stopped working after I logged in
https://linustechtips.com/topic/443722-psu-help/#findComment-5946812
Please don't get a CX600M. They have a 30C ambient limit, which basically means they don't do well at all in a warm PC case. They should be used for office and basic builds only, as stated on Corsair's site.
An EVGA B2 is a much better choice in terms of quality, or anything from Seasonic.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946822
Alright, I honestly have no idea what the hell happened there.
If you have anyone who know a lot about computer IRL, try asking them to help you out. At this point it's beyond my knowledge.
True, but those cost a lot more.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946824
The extra cost is worth it on the PSU. Or pretty much anything decent, other than the CX series.
For about $10 more, you can get a SeaSonic S12II 620W or a Semi Modular version for another $10
Corsair's CX series are cheap, and you get the build quality of a cheap PSU, which is really not what you want.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946850
Very true. My personal experience with that PSU has been fine but if it's not exactly known for quality, a higher-end PSU would be appropriate.
https://linustechtips.com/topic/443722-psu-help/#findComment-5946855
Decided to give it another shot and magicly it's been running fine running under load on 3d Valley for the past 20 mins
https://linustechtips.com/topic/443722-psu-help/#findComment-5947938
That's extremely weird but good to hear! I hope it doesn't give you any trouble in the future.
https://linustechtips.com/topic/443722-psu-help/#findComment-5948058
Probably the fact I used another power cable that's why it worked lol.
https://linustechtips.com/topic/443722-psu-help/#findComment-5948069
That PSU is very much bad - change it :D
I should know - I use to own one
https://linustechtips.com/topic/443722-psu-help/#findComment-5948074
no no no no no no no, no. . . . no!
no CX!
https://linustechtips.com/topic/443722-psu-help/#findComment-5948090
The CX or thermaltake?
EVGA, SeaSonic or Super Flower - do NOT settle for anything bellow that for a higher end system.
https://linustechtips.com/topic/443722-psu-help/#findComment-5948114
both are bad - Thermalfake is slightly better but still bad
https://linustechtips.com/topic/443722-psu-help/#findComment-5948117
Get  a SeaSonic M12II Evo 720W if you want a good quality modular 700W PSU
https://linustechtips.com/topic/443722-psu-help/#findComment-5948130
