I have an Alienware 18 with I7-4910MQ, Dual R9 M290X  and 64GB RAM.  I've never had any problems with graphics or fps but in the new Metal Gear Solid I have problems with the resolution. I can play every settings on max but the resolution doesn't go higher then 1280x720.. normally i play in 1920x1080.. could you tell me how to fix this?
https://linustechtips.com/topic/443682-1280x720/
