CPU DECIDE HELP ME!
well in terms of ram, just pick the 2133mhz realy.
You willl not realy benefit from those more expensive 3000mhz modules AT ALL.
Next to that, i dont think that the Xeon E5-1620-V3 is realy the most ideal cpu for gaming.
Of course you will be able to game on them, but i would recommend to grab the 5820K i7 instead.
The 5820K is unlocked, so it can be overclocked for better gaming performance.
Xeon E5´s are basicly not ment for gaming,
although a 3.5GHz Xeon E5 should be capable, but still it does not make any sense to use this chip for gaming.
5820K is a better choice clearly.
Also using a Xeon E5 on a X99 board in general doesnt make any sense.
Because X99 simply lacks on certain feutures.
Asrock X99 boards are an exception on the rule, those boards do support feutures like ECC memory support.
But stil, if you wanne benefit the most of a Xeon E5, you simply should grab a server grade c-series chipset mobo.
And those server grade boards, are not realy ment for gaming either.
So honnestly the Xeon E5 is not the best choice for your needs.
Grab a 5820k! ![]()
