CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($229.99 @ Micro Center)
Motherboard: EVGA Stinger Mini ITX LGA1151 Motherboard  ($199.99 @ Amazon)
Video Card: Gigabyte Radeon R9 390X 8GB Video Card  ($383.98 @ Newegg)
Monitor: BenQ GW2765HT 60Hz 27.0" Monitor  ($351.99 @ Amazon)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  ($119.95 @ Amazon)
Total: $1849.50
Generated by PCPartPicker 2015-09-02 21:09 EDT-0400
Basically, I'm building a gaming rig for my best friend's birthday. He's a pretty cool guy and I wanted to make his sweet sixteen one of the best. There's just one problem... I have a $1500 budget dictated by my parents; it's my money, but they're in control of what I do with it. I can't stretch the budget (even by a cent). OS is already owned. It has to include the same peripherals except for the monitor (which has to remain IPS @ 2560 x 1440). Please help me on this! I have until the fifth to purchase parts; his b-day's on the 20th and I want to allot enough time to deal with issues.
Edited by Godlygamer23
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/442941-help-me-lower-build-cost/
8GBs of Ram
Cheaper Motherboard
Please don't use the 500w Included power supply...
Cheaper mouse and keyboard.
Umm. Dunno...
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936389
I wouldn't run a 390x on a hadron PSU, just saying.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936395
You could change out the 2k monitor for one that is around $300 and asrock's motherboards are usually cheaper. You could just get one 8gb stick and upgrade to another later. Also, like the above comments stated the r9 390x will most likely need a more powerful psu.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936417
Did the best I could m8
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($111.98 @ Newegg)
Memory: Kingston Savage 8GB (1 x 8GB) DDR3-1866 Memory  ($45.97 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($75.60 @ SuperBiiz)
Total: $1570.43
Generated by PCPartPicker 2015-09-02 21:27 EDT-0400
The 390X wont be much different from the 390X to be worth $60 more...
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936431
You could change out the 2k monitor for one that is around $300 and asrock's motherboards are usually cheaper. You could also just get one 8gb stick and upgrade to another later.
Need 2K for editing, would've used 4K. but it's not in budget.
8GBs of Ram
Cheaper Motherboard
Umm. Dunno...
ARMA III for 12 GB
It's the only 1151 ITX MOBO
EVGA is trusted for PSU
No peripheral changes
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936447
Total: $1570.43
Overbudget and needs 16 GB.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936456
the sacrifices are coming then m8.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936463
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler ($34.90 @ Newegg)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard ($136.89 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory ($42.30 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.50 @ SuperBiiz)
Video Card: MSI Radeon R9 390 8GB Video Card ($319.98 @ SuperBiiz)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case ($98.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($66.60 @ SuperBiiz)
Monitor: Asus PB258Q 60Hz 25.0" Monitor ($319.99 @ Newegg)
Keyboard: Corsair STRAFE Wired Gaming Keyboard ($104.64 @ Amazon)
Mouse: Logitech MX Master Bluetooth Wireless Laser Mouse ($96.78 @ Amazon)
Total: $1490.56
Generated by PCPartPicker 2015-09-02 21:32 EDT-0400
Maybe get an SSD for him on Christmas? Also I changed the keyboard for a good reason. Check it out, otherwise you go over budget.
Um.. About it...
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936475
Why not Haswell?
Could do if i7 and 4 cores.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936477
ARMA III for 12 GB
8GB is enough.
Small,lesson on PSU. Don't trust the company, trust the model. Not EVERY EVGA is good. EVGA Rebrands PSUs from companies such as Super Flower, SeaSonic, and CWT, Few more. Well the only 500w EVGA PSU I know of is not very good. Don't get it. Trust PSUs from companies like SeaSonic, Delta, SuperFlower, or FirePower. If the PSU isn't made by one of these companies it's most of the time not a tier 1 or 2 PSU.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936490
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($232.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($64.80 @ SuperBiiz)
Memory: Kingston 16GB (2 x 8GB) DDR3-1600 Memory  ($73.80 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.20 @ SuperBiiz)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($329.99 @ Amazon)
Case: NZXT S340 (White) ATX Mid Tower Case  ($62.10 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.70 @ SuperBiiz)
Total: $1478.59
Is quad core with 8 threads. Equivalent of ~i7-4770.
I like this except for the PSU Choice. Get a EVGA B2 750w or EVGA GS 550-650w. Much better.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936498
Total: $1478.59
Close, but no cigar; he needs multimedia keys and a 27' monitor.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936499
8GB is enough.
I believe the 500W PSU inside of the Hadron is actually really good. I remember @TimmyTechTV talking about it in one of his videos.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936502
Linus has a video on the case, too.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936508
Alright if his isn't good enough, take my build, throw the K70 in there and it'll be about $5 over budget.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936511
The ONLY 500w PSU made by EVGA is not good. It's one of there lowest end power supplies. Don't say it's another one they only make one 500w PSU.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936526
He needs an i7 for rendering and editing. This is a PC to last him ten years. No joke.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936530
this one is an SFX and it's gold rated ?
afaik it's their only good 500 watt PSU and they don't sell it as an individual item, it's unique to the hadron.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936537
CPU Cooler: be quiet! SHADOW ROCK LP 51.4 CFM CPU Cooler  ($39.90 @ Newegg)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($78.98 @ Newegg)
Video Card: PowerColor Radeon R9 290 4GB TurboDuo Video Card  ($232.98 @ Newegg)
Total: $1468.34
Generated by PCPartPicker 2015-09-02 21:42 EDT-0400
I think I may have cracked it @The Official Czex
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936538
Ten years? Yeah no... I'm sorry but give me a PC from ten years ago that can run newer programs. We can't determine how long pcs will last. A 980Ti Could be a useless card next years because game devolpers decide to make games around PC,instead of console. Most people upgrade every 2 1/2 yeses the longest I've seen people last is 5 years. I can go fire up my stepdads old PC that has 1GB of ram, some old GPU from 2001 ect and I'll tell you how it runs.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936544
Total: $1468.34
Needs 8GB frame buffer... You know what, guys? Just forget about it, I'm asking the impossible.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936547
Well, at least as long as possible.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936549
why does he need 8GB frame buffer? Very few cases you actually need that...
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936557
2560 x 1440 monitor @ 60 Hz needs a fairly high frame buffer. 6 GB would do it, but 4 GB is cutting it close.
https://linustechtips.com/topic/442941-help-me-lower-build-cost/#findComment-5936568
