So I just backed up my ipod touch to my computer, it's an HP Envy 17 do any of you know where I can view the backed up files?
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/442936-ipod-help/
iTunes version?
Jailbroken?
What files? IPAS? IPSW? APP DATA?
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936311
iTunes version?
Jailbroken?
Photos/Videos
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936326
Ok, then how do I pull photos and videos from my iPod Touch?
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936348
itunes backup doesn't let you get those
just go to my computer >ipod touch  then copy paste
It's not showing up :/ I went to This PC and there was nothing where the ipod should have been displayed...Btw this is an old iPod touch it may even be first gen I can't remember
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936365
It needs to be ON and UNLOCKED.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936391
It's On and Unlocked because I'm deleting apps as we speak :P
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936406
Is it an official lightning cable?
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936418
Yep it's a certified cable that I bought at the Georgetown University student store and if you need further proof, they are a licensed vendor of apple products and they sell ipads and macbooks
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936437
Does windows grab drivers?
If not, it's probably the cable either failing to transfer data.
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936452
Yay I'm the 199th subscribbler to your channel :D
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936457
Here's the weird part everything except photos shows up under "On My device"
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936497
Hmm. Have you done a restart of all devices involved?
: D
https://linustechtips.com/topic/442936-ipod-help/#findComment-5936669
I don't understand your goal. What exactly are you trying to do?
If you made a normal iTunes backup of your iPod and you want to copy data from the backup, you can't without third party software.
But if you have the iPod, why do you need/want to dig through the backup? If you have pictures on it, that typically means you either 1) took them with the iPod, so you can just go into the DCIM folder to copy them off like any other camera. 2) synced them to the iPod, which also means they're already on your computer because, well, you synced them from the computer.
If neither of those circumstances fit what happened or what you're trying to do, reply and be much more specific.
https://linustechtips.com/topic/442936-ipod-help/#findComment-5937526
I just want to pull the pictures off but my PC isn't picking up the iPod.  Itunes picks it up but there is no option for videos and photos under on this device so I can't pull those off.  I just want to know how to get the pictures off the ipod
https://linustechtips.com/topic/442936-ipod-help/#findComment-5939807
So the iPod is appearing in iTunes but not in Windows Explorer?
The pictures you want to offload are the pictures that were taken by the iPod?
https://linustechtips.com/topic/442936-ipod-help/#findComment-5940251
