Wireless Adapter vs Range Extender?
Solved by Oshino Shinobu,
I'm probably just going to get these
But, sometimes I will need a wireless connection, any thoughts on what kind I should get?
Edit: Wait, could I use these?
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124482
The second set should work fine. However, you will be limited to 200Mbps on both connections (theoretically half that for each PC if they're maxing the connection at the same time), so it could be an issue for transfers across the local network, if you have any fast network storage.
If you don't have that, then they'll work fine.
