Stuck at installing driver for 950m
Go to solution Solved by Guest,
Download the drivers from NVIDIA's website, not via the Geforce Experience thing.
I just bought a laptop with a 950m. The driver wont update after it upgraded to windows 10. I attached a picture of what keeps happening. just gets stuck there forever. Any suggestions?
post-250282-0-38874900-1441208309_thumb.
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/442593-stuck-at-installing-driver-for-950m/
http://www.geforce.com/drivers
After you've done a manual graphics driver installation, it will update automatically.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
Thanks guys
