Hi guys, i need your opinion on building a  skylake pc. Right now i have a pc that uses i3-3220 as cpu but i decided to upgrade. My friend helps me build about 3 years ago so i dont really have that much experience building my own. Currently im looking forward to buy i5-6600k (cpu), msi z170a gaming pro (mobo) and kingston hyper x fury 8gb ddr4 2666MHz (memory), and all the other part such as psu, and HDD i will be using the old one and as for the gpu I'll upgrade to gtx970 from next moth salary. :P   I need you opinion is this a good build overall and after i've done setting it all do i have to configure the bios or just leave as it be? Thanks in advance and sorry for asking such a noob question! :(
https://linustechtips.com/topic/441836-need-help/
Please tell us what you're wanting to do with the PC, your budget and your location. This way we can give you the best possible build.
Sig under construction.
https://linustechtips.com/topic/441836-need-help/#findComment-5921828
You might want to rethink about reusing the PSU and HDD because the age, how old are they?
Plus you might want 16gb DDR4 if you are not thinking about upgrading for another couple of years
Everything else is good
Just joined the forum? Read this:
A Quick Guide To Get Started
Need Help Doing Something? Read this:
Guides & Tutorials Catalog
Need a New SSD? Read this:
Droidbot's SATA3 SSD Tier List
Need a New PSU? Read this:
PSU Tier List
In the mood for some memes? Look at these:
Linus Memes
Want to know my PC Specs and Peripherals?
CPU - Intel Xeon E5 2609 v3     Motherboard - ASRock X99 Extreme3      RAM - 16gb HyperX Fury DDR4      GPU - EVGA Nvidia GeForce GTX 770 SC
Case - Inwin 103       Storage - HyperX Savage 240gb SSD      PSU - 550W Enermax NAXN      Display(s) - 2x Lenovo L27i-28, Dell 24"      Cooling - Corsair H100i Platinum     Keyboard - Corsair K95 Platinum MX Speed      Mouse - Logitech G900      Sound - Audio Technica ATH-M50x     Operating System - Windows 10 Pro
Join the LTT F@H Team!
You can help scientists studying Alzheimer's, Huntington's, and many cancers by simply running a piece of software on your computer.
Start now: Folding@Home Install Guide and Links
https://linustechtips.com/topic/441836-need-help/#findComment-5921836
Thanks for the reply! Mostly gaming, i choose to buy skylake as i think i dont have to upgrade it for 3 or more years. I live in malaysia and some of the pricing here is different than in the US though.
Thanks for the reply! My pc i about 3 years old. I do beleive the psu still have around 1 or 2 more years warranty. Isn't 16gb will be too much for gaming?
https://linustechtips.com/topic/441836-need-help/#findComment-5921857
16gb will be brilliant for the next 3 years and will work perfectly, but if you are on a tight budget, go 8gb because it might pull it off.
Or go 8gb and get an SSD, it helps, trust me  :)
PSU Tier List
Linus Memes
https://linustechtips.com/topic/441836-need-help/#findComment-5921872
What are you doing with your pc? I know that 16gb will be great for almost anything!
Noted I'll add in another 8gb ram together with gtx970 next month. Mostly gaming, one of the main reason to upgrade because right now with i3-3220 and gtx 650 most of the games i play will have stutter and stuck here and there. I'm using 27inch 1440p monitor though which i guess the main reason for all the problem.
https://linustechtips.com/topic/441836-need-help/#findComment-5921895
I occasionally play minecraft with flans mod using 8GB and it complains 'Insufficient Memory'
PSU Tier List
Linus Memes
https://linustechtips.com/topic/441836-need-help/#findComment-5921906
Adams, that's almost certainly because you have 32-bit Java installed. Make sure the only version of Java you have installed is 64-bit.
https://linustechtips.com/topic/441836-need-help/#findComment-5921914
That would work a treat with 16gb ram!
To Clarify, your pc will have:
 i5-6600k
Msi z170a gaming pro
 2x kingston hyper x fury 8gb ddr4 2666MHz = 16gb DDR4 2666MHz
GTX 970
What models are the GTX 970, psu and the hdd?
PSU Tier List
Linus Memes
https://linustechtips.com/topic/441836-need-help/#findComment-5921916
:lol: oops
PSU Tier List
Linus Memes
https://linustechtips.com/topic/441836-need-help/#findComment-5921919
1 question, do I have to change anything on the BIOS or should i just leave it be? Sorry for the noob question tho and thanks for your help!~
 i5-6600k
GTX 970
Planning to buy msi gaming gtx970, the psu im using right now is xigmatek tauro 700w and im using samsung 840evo 120gb (for windows) and 2TB western digital HDD
https://linustechtips.com/topic/441836-need-help/#findComment-5921928
sounds good :)
(sorry for the long wait for the reply, my keyboard broke)
PSU Tier List
Linus Memes
https://linustechtips.com/topic/441836-need-help/#findComment-5929556
