Mad max worth it?
Go to solution Solved by LancerBG,
will be half price in a couple months. wait if you can. Its not the kind of game you need to play as soon as its out.
GET IT
It's a carpg
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/441773-mad-max-worth-it/#findComment-5921071
I got it for $20 at cdkeys.com, its not even that expensive.
http://cdkeyprices.com/mad-max-cd-key
Downloads almost done, heard its running great (optimized/expected performance) from good gear, hope the story holds up, the action surely looks top notch as well as the camera work in the trailers.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/441773-mad-max-worth-it/#findComment-5921182
Done,downloading :D
https://linustechtips.com/topic/441773-mad-max-worth-it/#findComment-5921278
