Without a doubt, the first one.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/441426-need-help/#findComment-5916623
The first one of course. What in the world are you going to do you 22 fans for Gaben's sake? Make a air conditioner?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/441426-need-help/#findComment-5916641
HELLZ YEZ
I guess I wanted to prove air cooling can beat water AIO
You know that no case can fit 22 fans, unless you are going to make a case out of these fans.
https://linustechtips.com/topic/441426-need-help/#findComment-5916666
First one with some changes. Get a less expensive case and put the money into a larger ssd and better psu.
https://linustechtips.com/topic/441426-need-help/#findComment-5917323
  • 2 weeks later...
Yup
The
Rosewill BlackHawk-Ultra Full Tower Gaming Computer Case
Advanced Cooling System:
-Front (first layer) 2 x 140mm Red LED Fan (pre-installed)
-Front (second layer) 2 x 140mm Fan (pre-installed)
-Rear 1 x 140mm Fan (pre-installed) or 1 x 120mm Fan (option)
-Top 2 x 230mm Red LED Fan (pre-installed) or 3 x 140mm Fan (option) or 2 x 180mm Fan
-Side 1 x 230mm Fan (pre-installed) or 9 x 120mm Fan (option)
-Bottom 1 x 140mm Fan (option)
https://linustechtips.com/topic/441426-need-help/#findComment-5992794
Yup
The
That's absurd, please don't do that. It's bad for the air flow configuration and bad for the budget.
https://linustechtips.com/topic/441426-need-help/#findComment-5992858
Why is it bad airflow Does it make it like a wind tunnel inside the case
Yes, air will go where it shouldn't go to. Just have a 140mm exhaust and dual 120mm intake, more then enough.
https://linustechtips.com/topic/441426-need-help/#findComment-5997096
