Need help identifying memory.
Go to solution Solved by typographie,
PC3-10600 is another name for DDR3-1333.
I had bought a pre-built computer years ago when I first started getting into pc gaming I've since then built my own pc. I've been trying to figure out what type of memory my old pre-built had. I used to speccy to find out the manufacture which is spectek I believe but I can't seem to find any information on the memory or the company. The only things on the sticks. http://i.imgur.com/BK3f4JH.jpg http://i.imgur.com/TEahHgh.jpg
https://linustechtips.com/topic/441236-need-help-identifying-memory/
