Hey guys, so i am hoping to get a job soon, and apparently (my friend already works there) i can earn up to $25 on public holidays and on sundays per hour!! I am going to buy a plethera of items for both my PC and motorbike.
Anyway, i was planning on water cooling my PC. And no, i'm not going to water cool my i5 4670 and gtx 770 2gb. I am going to upgrade to a K series CPU and hopefully a GTX 980 or an AMD card or any other high end Nvidia/AMD card. Anyway, i was wondering if you guys could help. I am hoping i'll have around $300ish AUD at the time of doing this, but the cheaper you could make it without sacrifcing quality would be better. For colours such as dye and or tubing yellow please.
More info about my PC and whether it'll be compatible:
I have an RM850 PSU.
Carbie Air 540 case
MSI Mpower max z87 mobo.
Will the case and PSU be able to handle/have enough room for a loop?
Was hoping to have the pump where the PSU is in my case.
~Elias
EDIT: http://www.pccasegear.com/index.php?main_page=index&cPath=207_160 please if you make a shopping cart or list use this website. Once the shopping cart is made there should be a 'share' option, and then a link will be copied to your clipboard.
Edited by melias24
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
https://linustechtips.com/topic/441092-planning-on-water-cooling/
Maybe wait until you have that money in hand?
I am hoping to plan now and get help with a plist with a total rpice, so then i can save that money and have a rough idea on how much it'll be.
Thanks! Could you recommened some certain parts and brands if on a budget?
B
b
Just buy the Corsair H80i. It's a great water cooling solution!
CPU Intel Core i5 4670k 4.4Ghz Motherboard MSI Z87-GD65 Gaming RAM Kingston HyperX Beast 16GB 2400Mhz
GPU GIGABYTE GTX 780 Windforce 3X OC Case Cooler Master HAF XM Storage Samsung 850 PRO 256GB, Samsung 840 EVO 256GB, Western Digital Blue 1TB
PSU Corsair RM 750 Display(s) Philips 22" Cooling Corsair H80i Keyboard OZONE Strike Pro
Mouse GIGABYTE M7 Thor Sound Genius 5.1 Surround Sound System Operating System Microsoft Windows 10 Pro Voltage Control NZXT Sentry 3
the best way to save is probably to buy a kit like this https://shop.ekwb.com/ek-kit-l240-1
and theres always the option to do the ghetto cooling shown in scrapyard war 2 :P
I would but i just want to get experience in water cooling and i want to gain knowledge on how to do it.
Thanks! Do you know anything about 2 in 1 resv. and pump's? Is this a better option than having the 2 sperate?
Also just a question, would you know the best size rad for a loop that is just cooling the CPU and GPU? Would a 360mm rad be over kill? I has my eye on this http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_297_922&products_id=18730 or the 240mm version.
360mm would be good, generally speaking you want 120mm of rad per component in the system minimum, so you'd have 180mm per component more or less, so you'd have a bit of breathing room.  I personally went a bit over kill and have 360 + 240 for CPU and GPU so I can run my fans at a lower speed for quieter operation.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
Ah ok so 360 for both CPU and GPU will be good enough? I was going to go for a 240 as it's cheaper but i want optimal cooling so i might go with a 360. Did you buy your own parts or did you buy a watercooling kit?
The price difference between and 360 & 240 are pretty negligible (my 240 was around $50 and my 360 was around $60).  Yea I picked out all my parts, as I wanted very specific pieces.  But a kit can be a good starting point.
it does make the build easier and takes less space in general
you can also check out the 5.25inch bay 2in1 pump res combo if you dont have much room in your case
usually the amount of radiator space can be calculated by (the number of CPUs + the number of GPUs + 1) * 120mm
so 360mm would be perfect in your case if your case supports it
