Hey guys,
So I've had my triple 27" setup for a while. I have my yeti on a rather small, cheapo boom arm. It doesn't work well, and I have it set up on the front right corner of the desk, and it stretches as far as it can, and I put it low  and it's in the middle of my desk, and I look over top of it at my monitors.
When gaming it's a bit of a hastle, and I'm always moving this POS around. What booms are you guys using, and how do you have them managed around your setups?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/440406-setting-up-mic-boom/
Pretty much the same as yours, although my mic isn't as tall as yours so it doesn't get in the way as easily.
Like I'm happy I bought my mic, because it was a great sale on black friday (like 50% off or some shit). But in hindsight I wish I got an AT2020
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/440406-setting-up-mic-boom/#findComment-5903836
I can't afford a mic......or anything..... :(
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/440406-setting-up-mic-boom/#findComment-5903849
