try running in compatability mode
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/440327-any-help-for-lol/#findComment-5902897
So after o upgrade my PC to Windows 10, I can't play LoL anymore. After I clicked 'Start LoL' nothing pop up. Any fix?
Taken from the LoL forums;
Bring up Task Manager (ctrl+alt+delete)
End Process for all League of Legends Applications
Right Click your LoL Launcher Icon
Go to Properties
Compatibility Tab
Check/UnCheck the Run this Program in compatibility mode:
Find Suitable Mode to Operate LoL (mine was Vista S1)
Run as Administrator
Apply Settings
(May have to restart computer, I have had to a couple times then other times I do not)
ReLaunch League
EDIT: Just saw your latest post. Maybe try a fresh install of LoL if possible?
https://linustechtips.com/topic/440327-any-help-for-lol/#findComment-5902929
