I am building a gaming PC with an Intel I5-4590 or i5-4690k, I have the NZXT S340 Case with a 650w PSU, R9 380 4GB and a 240GB SSD.
I would appreciate any help with which motherboard to choose, It would need to be good as I game/record/stream, I would also need 4< USB Slots
Thanks.
Part List:
i5-4590 // i5-4690k
8GB RAM (2x4GB)
R9 380 4GB (Graphics Card)
240GB SSD
650w PSU
NZXT S340
https://linustechtips.com/topic/440132-build-help-motherboard-help/
Buy the cheapest motherboard that suit your needs.
If you are buying K series processor, go for Z97 board.
If not, H97 board.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
Get any cheap one from a reputable brand such as: ASUS, MSI, Gigabyte, EVGA etc..
If you get the 4590 then go for a H97 board it will be cheaper and better for not overclocking.
If you get a 4690k then go for a Z97 board as it will help overclocking.
*EDIT* Just realised I copied the post above me... Sorry ;)
OK thank you for the help everyone. Any specific H97 model, if I go for the i5-4590, or does it not really matter?
Honestly, it's a bit cheaper to go with the i5-4460 than the 4590.
Asus, MSI and Gigabyte are good brands.
